This issue is usually because one of the HDDs connected to the computer has died and the controller is stuck trying to ID the dead drive.
Disconnect all your HDDs then power on and see if it gets past it, if it does then you need to connect the drives back up one at a time until you find the one causing the stall.
Main Rig:-
Server:-
https://linustechtips.com/topic/1188689-stuck-on-vmi-pool-data/#findComment-13558967
