Help me out pls
Go to solution Solved by MrBrightSyde,
Either the Scythe Ninja 5, Mugen 5, or Fuma 2 are going to be your best bets.
The Ninja 5 is the quietest and coolest, but if you want to actually see your RAM (or add more/replace it later), the Fuma 2 and Mugen 5 are better.
Soo im not sure which cooler route to take, With my CPU being a 3600x ive been juggling between getting either a Noctua NH-U12S  or the Noctua NH-U12A
Im going to OC it to 4.2 and tbh the stock cooler is loud soo i dont want to keep it.
But let me know if any of those coolers would be able to keep my temps down when running AAA games
https://linustechtips.com/topic/1188607-help-me-out-pls/
8 minutes ago, Demonic Donut said:
The slim version allows for more obstruction around the CPU, like very tall/crowded RAM etc because it is smaller (thinner)
do you think i should get the Scythe Mugen 5 Rev.B CPU Air Cooler, 120mm instead or should i stick with the noctua one
https://linustechtips.com/topic/1188607-help-me-out-pls/#findComment-13559892
27 minutes ago, OreoShake said:
well im not sure then, but the slimmer still does the job of cooling down that CPU right?
They both will do fine, but I would imagine the S would have slightly higher temps due to less surface area to disipate heat.
I always recommend the best cooler you can afford. The scythe seems to be about the same cooling wise as the U12, after a couple minutes of googling, so it comes down to cost/looks. The Noctua gets you an extra fan, but double the price vs the scythe is a big pill to swallow. If you are spending that much, get a Noctua D15 if you can fit it instead of the U12.
What are your specs other than the 3600x?
You don't need to spend $90 on a cooler, the $40 scythe will do fine.
https://linustechtips.com/topic/1188607-help-me-out-pls/#findComment-13560028
GPU is a RX 2060
2x8 of RAM
500gb on a M.2 SSD
2TB Harddrive by Seagate
Mobo - MSI b450 Tomohawk Max
500watts Bronze PSU
https://linustechtips.com/topic/1188607-help-me-out-pls/#findComment-13560160
what do you mean when you say a big pill to swallo though lmao
https://linustechtips.com/topic/1188607-help-me-out-pls/#findComment-13560164
How tall of RAM?
Its a figure of speech. Its difficult to justify spending $90 on a U12 when you can spend $40 on a Scythe and get pretty similar performance. The U12 might be quieter though. It just depends on your budget and preferences.
https://linustechtips.com/topic/1188607-help-me-out-pls/#findComment-13560209
G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200
im not sure how to check how tall it is , but this is the ram that im going too be using,
Can you tell me how to check it though? ive never even thought that was important, this is my first time getting a cpu cooler btw.
https://linustechtips.com/topic/1188607-help-me-out-pls/#findComment-13560255
22 minutes ago, Demonic Donut said:
How tall of RAM?
oh btw the case is going to be a NZXT h510 elite most likley or just a p400a
https://linustechtips.com/topic/1188607-help-me-out-pls/#findComment-13560314
MAIN PC:
CPU: AMD Ryzen™ 7 7800X3D Motherboard: Gigabyte B650 Eagle AX CPU Cooler: EVGA CLC 240 GPU: EVGA RTX 3080 FTW3 Ultra RAM: TEAMGROUP Expert T-Create 32GB (2x16GB) 6000Mhz CL30
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
Former parts that I've used:  Intel® Core™ i3-9100F, Intel® Core™ i9-9900k, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti, EVGA 3060 XC, ASRock Z390 Phantom Gaming 4-CB, Gigabyte Z390 Aorus Pro Wifi, ADATA XPG 16GB (2x8GB) 2400Mhz CL16, Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15, Scythe Fuma 2, Acer XG270HU.
https://linustechtips.com/topic/1188607-help-me-out-pls/#findComment-13560629
