99/100 times: No
https://linustechtips.com/topic/1188526-ssd-cooling-question/#findComment-13557857
If its NVME you will generally get more consistent performance with a heatsink, otherwise case airflow should do the trick.
https://linustechtips.com/topic/1188526-ssd-cooling-question/#findComment-13557864
1 minute ago, Romans122 said:
what about long hours gaming ?
They only heat up under heavy load, gaming wont be.  They also cool down really quickly.
https://linustechtips.com/topic/1188526-ssd-cooling-question/#findComment-13557869
You'll be fine.
If somehow you get a drive up to it's inoperable temperature, it will throttle
https://linustechtips.com/topic/1188526-ssd-cooling-question/#findComment-13557870
yes its a nvme, I gunna get the Sabrent Rocket
If your motherboard doesn't come with a heatsink on the M.2 slot then get the version of the SSD with a heatsink on it, then never worry about it again.
But honestly gaming is not going to stress it, only really large file transfers are likely to cause throttling.
https://linustechtips.com/topic/1188526-ssd-cooling-question/#findComment-13557874
Or just don't worry about something that only serves a cosmetic purpose.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/1188526-ssd-cooling-question/#findComment-13557880
do you know if the msi b450 mortar max comes with a heat sink ?
https://linustechtips.com/topic/1188526-ssd-cooling-question/#findComment-13557887
4 minutes ago, Romans122 said:
so I don't need one ?
Do you need one for gaming?  No.
But they are definitely NOT merely cosmetic, if you are pushing their top speed and its a good SSD (SLC or MLC) then they DO thermal throttle.  Its just not something you are ever going to experience gaming.
Considering the price with and without is usually minimal or even none-existent, it doesn't hurt to have one.  Obviously you need to know if your motherboard already comes with one or else you wont be able to fit an SSD that has one pre-applied.
https://linustechtips.com/topic/1188526-ssd-cooling-question/#findComment-13557896
could you please check this motherboard msi b450 mortar max, as I am still new to pc building and would appreciate the help.
https://linustechtips.com/topic/1188526-ssd-cooling-question/#findComment-13557908
With the exception of some fringe usecases, like people who buy high end SSD's for scratch disks or servers, no. A lot of the time, heatsinks aren't even actually functional. They're like the metal backplates on GPU's, that actually just make things hotter.
https://linustechtips.com/topic/1188526-ssd-cooling-question/#findComment-13557991
No SSD's are SLC anymore, and there are almost no 2-bit MLC ones. And yes, many heat spreaders are cosmetic. They're on their because they don't cost much and looking cool makes stuff sell more. Why do you think DRAM has those worthless heatspreaders?
https://linustechtips.com/topic/1188526-ssd-cooling-question/#findComment-13558013
But again, it doesn't hurt.  With electronics cooler is almost always better for life span.  Although NAND does retain data better if written to hot.
https://linustechtips.com/topic/1188526-ssd-cooling-question/#findComment-13558032
