Hey i am about to finish building my 1st ever gaming PC. So far the build is a ROG SRTIX X470, Ryzen 7 3700x, Evo cooler, Corsair vengeance pro rgb, Nvidia RTX 2070 Super. Now my idea is i would like to over clock it to something quite reasonable like 4.0Ghz but i have no idea what i am doing. I have seen a lot of videos on what to do but i was hoping someone on here would have a very similar build and can give me some guidance on what to change and what not to change. Any and ALL help is much appreciated.
https://linustechtips.com/topic/1188440-i-need-oc-help-please/
12 minutes ago, Niswendel said:
Hi,
I would suggest upgrading to a X570 motherboard if your budget alllows, according to the following article, https://www.digitalcitizen.life/x570-vs-x470-motherboards, it allows for better overclocking.
Hope I helped
Hey Erm yeah it might be a little to late as the board is on route to me via the delivery.. I dont want to go crazy with OCing like i said 4.0Ghz would be perfect for me.
https://linustechtips.com/topic/1188440-i-need-oc-help-please/#findComment-13557242
Other then that I'm out of my knowledge, so I wont give you made up stuff:)
https://linustechtips.com/topic/1188440-i-need-oc-help-please/#findComment-13557248
Your 3700X will naturally reach 4.0Ghz all cores without any modifications. While running games it may boost to 4.4Ghz.
For all core OC you could try for 4.5Ghz but it's not recommend if you not used to overclocking.
Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB
            CPU: Ryzen 9 5900X          Case: Antec P8     PSU: Corsair RM850x                        Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM
            Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition
https://linustechtips.com/topic/1188440-i-need-oc-help-please/#findComment-13557313
