HELP! ROG ZEPHRYUS GA502DU won't charge or turn on.
Solved by Edward Brinkman,
Unfortunately it sounds like your motherboard is dead. Provided you haven't blatantly mistreated the laptop, you shouldn't have any issues with using the manufacturers warranty to replace or repair the laptop. However, be prepared to be without a laptop for quite a while, as i may take some time for them to honor the warranty and your new/ repaired laptop to arrive.
Featured Topics
Beeswitt ·
Posted in Troubleshooting0 -
3
CrowTheRobot ·
Posted in Windows1 -
1
6
uncanny_mac ·
