3 minutes ago, wassil said:
i want a build that will hold against upecoming games (next gen consoles)
so basically you want a 6 year old PC?
/s
if there's no specific workload you need an 8 core CPU for, the Ryzen 5 3600 (non x, save the money) and a better GPU is ideal for a gaming PC.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1187457-first-build-need-help/#findComment-13550664
7 minutes ago, wassil said:
hey guys its my first build and iam stuck between two choices i want a build that will hold against upecoming games (next gen consoles)
build1: ryzen 5 3600x + rx 5600xt
 vs
 build2: ryzen 7 3700x + 1660 super
r 5 3600 (non-x, x literally only comes with a factory oc, its useless) and a 5600xt/5700
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
https://linustechtips.com/topic/1187457-first-build-need-help/#findComment-13550685
/s
in my country the 3600x and the non X are almost on the same price like not higher than 15$, so a 6c/12t will be enough for the next 6 years ?
https://linustechtips.com/topic/1187457-first-build-need-help/#findComment-13550686
 vs
Agreed.
If all you want is a gaming PC the R5 3600 (non X) is the best choise and spend the remaining money on the best possible GPU.
CPU: i9 9900K   Cooler: NH-D15   RAM: Kingston Fury 4 x 8GB 3600MHz CL17   Mobo: ASUS ROG Strix Z390-F   GPU: ASUS 3080 TUF   Case: Be Quiet! 500DX   PSU: Corsair HX850i   Storage: 250GB Samsung 970 EVO NVMe (OS), 500GB Samsung 970 EVO NVMe (Games), 2TB Crucial BX500 SSD (Storage)   Monitor: Samsung Odyssey Neo G9.
https://linustechtips.com/topic/1187457-first-build-need-help/#findComment-13550688
Unless you can get a 3600X for the same price as a 3600 (like I did), there's no good reason to buy the 3600X. You might as well spend the $15 on a cheap Wish dragon dildo or something (not buying advice).
And yes, 6c/12t should be good for a while. And in the event that you need to get more cores, you could switch CPUs in minutes.
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
https://linustechtips.com/topic/1187457-first-build-need-help/#findComment-13550694
I would believe so but 6 years is a long time so hard to say.
And it also depends on what type of resolution and frame rate your monitor has.
For 1080p @ 60hz is will be fine.
1440p @ 144hz your GPU will struggle.
I would say you need 5700xt / 2070S minimum for 1440p/144hz.
https://linustechtips.com/topic/1187457-first-build-need-help/#findComment-13550706
is it bad to cheap up on a psu ?
https://linustechtips.com/topic/1187457-first-build-need-help/#findComment-13550718
next 6 years? We can't see the future so we don't know. you can upgrade with any decent AM4 motherboard though so not like it will be a problem.
it's one of the worst things you can do when making a PC
Primary PC:
PSU tier list
https://linustechtips.com/topic/1187457-first-build-need-help/#findComment-13550728
YES don't buy a cheap PSU.
Most decent/good PSUs has 5-10 years of warranty.
But an +80 bronze 550W-650W  from a respectable brand will be fine.
https://linustechtips.com/topic/1187457-first-build-need-help/#findComment-13550746
between this two psu wich one is trustworthy ?
THERMALTAKE TOUGHPOWER GRAND RGB 650W ( tier A- on the list)
COOLER MASTER MASTERWATT 650 Gold (tier B on the list )
https://linustechtips.com/topic/1187457-first-build-need-help/#findComment-13550753
https://linustechtips.com/topic/1187457-first-build-need-help/#findComment-13550759
1 minute ago, wassil said:
The one that's higher in the list. I have a A- PSU and it hasn't exploded, yet.
https://linustechtips.com/topic/1187457-first-build-need-help/#findComment-13550764
neither is necessarily more "trustworthy" so you should get the higher rated one.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1187457-first-build-need-help/#findComment-13550770
this is my final list let me know what you guys think
ryzen 5 3600
msi b450 tomahawk
2x8 3000mhz
256ssd m.2 + 1tbhdd
rx5700
THERMALTAKE TOUGHPOWER GRAND gold RGB 650W
also should i build it myself or let the seller build it for me ( i have watched alot of videos iam confident i can build it but let me know you guys have experience
https://linustechtips.com/topic/1187457-first-build-need-help/#findComment-13550785
ryzen 5 3600
msi b450 tomahawk
2x8 3000mhz
256ssd m.2 + 1tbhdd
rx5700
Looks alright.
The only thing I would suggest is slightly faster memory as ryzen CPUs benefits from fast memory.
3200mhz/3600mhz with decent timings.
But the memory you have choosen isn't bad and will work fine.
https://linustechtips.com/topic/1187457-first-build-need-help/#findComment-13550796
building yourself is probably the best way to do it, if you have videos to refer to then it's fine.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1187457-first-build-need-help/#findComment-13550807
Building a PC isn't that hard as there are a lot of good guide videos and instructions on the interwebs...
It is basically like building very expensive Lego.
Take your time, study and read the instructions and you will be fine.
https://linustechtips.com/topic/1187457-first-build-need-help/#findComment-13550828
