Budget and country are the most important things for you to tell us. Unless you want us to just build insane gaming parts lists for you
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1187366-building-a-pc/#findComment-13550088
If you want to run a single monitor at 4K for gaming and just have the other two not be gaming then something like this would do very well HOWEVER I would advise waiting a bit to see what Ryzen 4000 (for the desktop) brings and if, in that time, any new Nvidia or AMD GPUs are announced as well. I keep hearing murmurs of Nvidia 3000 series GPUs but nothing solid on a release date. I left out hard drives for mass storage but you could pick up a single 6TB or 8TB drive depending on your needs. I went a bit heavy on the PSU just in case you need/want to go SLI/NVLink (just to burn money) in the future.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1187366-building-a-pc/#findComment-13550294
