Hi , this is going to be my first pc build, I just have a kind of crappy laptop right now so looking to upgrade. Mostly doing some uni schoolwork and gaming. I'm in the USA also, and would prefer to make an AMD rig but eh, doesn't matter too much to me. My budget is for somewhere between 2000 and 2200 ideally. I don't need too much storage either, only using around 300GB right now, so I would like to opt for solely a 1TB ssd if possible (or ideal? not entirely sure). Im planning to run around 3 monitors. I have all the other peripherals and a copy of windows 10. I would generally like to run upward of 60 frames, ideally 120 on medium settings (1920-1080) but that might be aiming too high. Generally playing Rocket League, WoW, Overwatch, nothing extremely demanding. Let me know what I should change on! (I also need wifi accessibility but not sure at all what is a good item for that would be)
https://pcpartpicker.com/user/fish558/saved/xbKbhM
https://linustechtips.com/topic/1186961-first-build/
For 2200 you can get this and this can play at least 120fps high.
Laptop: HP Spectre x360 13t, i7 8565u with 16 gigs, 512 gig  nvme ssd, UHD 620 4k
Other laptop: Acer Chromebook cb3 431 with 4 gigs, celeron n3060 with hd 400 and 16 gigs eMMC soon to be a minecraft server?
Remeber to tag people or else they wont see your post.
https://linustechtips.com/topic/1186961-first-build/#findComment-13546912
https://linustechtips.com/topic/1186961-first-build/#findComment-13546924
https://linustechtips.com/topic/1186961-first-build/#findComment-13546931
