Hi,
I am also looking to make this decision. Some tips for you to get replies: You need to provide more information, otherwise no one will be able to help you. What are you using it for, video editing, streaming, working from home, browsing social media? What are your current specs in the computer, post a list from pcpartpicker or something like that. Are you looking at budget priced cards, top tier or somewhere in between? The answer will be different for different price points.
The general consensus is this at the moment as far as I know with my limited knowledge:
AMD cards especially at the higher tier provide better performance per dollar or euro or whatever currency you use.
NVIDEA RTX cards are better if you want to stream using NVENC and want to make use of Raytracing which the cards are named for.
AMD Radeon cards are generally a cheaper option right now with great performance, in the higher tiers.(5700XT for instance) You may get replies from smarter and more experienced people if you give more information!
https://linustechtips.com/topic/1186370-gpu-help/#findComment-13542754
FYI, NVENC isn't realistically any better than AMD's VCN 2.0 anymore, and VCN can be used in OBS just fine, so you aren't limited by vendor for streaming anymore.
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
https://linustechtips.com/topic/1186370-gpu-help/#findComment-13543463
True but nvec brings surprisingly good encoding quality with really little to no affect on performance
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1186370-gpu-help/#findComment-13543555
Same for VCN... That's the point. There is no realistic difference between the two right now.
https://linustechtips.com/topic/1186370-gpu-help/#findComment-13544025
