Building a new PC, need some guidance on the PSU i should get, I used outervision it recommended 385W but if I look at the EVGA website for a EVGA GTX 1660, they recommend a minimum of 450W PSU. Also any recommended brands for PSU?
Motherboard:
MSI B360 GAMING PLUS ATX LGA1151 Motherboard
CPU: Intel Core i5-9400F
Memory:
Kingston HyperX Fury 16 GB (2 x 8 GB) DDR4-2666 Memory
Video Card:
EVGA GeForce GTX 1660 6 GB SC ULTRA GAMING Video Card
Storage: 1 x SSD 256GB
Storage: 1 x HDD 2TB 7.2K RPM
Other Device: 1 x Fan Controller Device
Keyboard: 1 x Gaming Keyboard
Mouse: 1 x Gaming Mouse
Fan: 4 x 140mm
Monitor: 2 x LED 22 inches
Computer Utilization: 8 hours per day
Gaming/Video Editing/3D Rendering Time: No Gaming / 3D Apps
Load Wattage: 335W
Recommended Wattage: 385W
Amperage: +3.3V: 10.1A, +5V: 10.3A, +12V: 20.8A
Recommended UPS Rating: 750VA
Generated by OuterVision PSU Calculator 2020-04-29 11:06:06
Thanks
https://linustechtips.com/topic/1186074-need-help-choosing-psu/
3 minutes ago, PauloThePanda said:
Isn't 450W too low?
If are going to overclock or upgrade ur GPU then 450w be low .If u have the budget then u can go to 550 gold PSU buy corsair
I recommended u to see this topic and select ur PSU
https://linustechtips.com/main/topic/1116640-psu-tier-list-40/
https://linustechtips.com/topic/1186074-need-help-choosing-psu/#findComment-13540495
Thanks, I will most likely go for the Corsair 550W 80 PLUS certified, the Gold is out of my price range and also I don't plan on overclocking, but just to be on the safe side.
https://linustechtips.com/topic/1186074-need-help-choosing-psu/#findComment-13540523
Is it VS550 then Don't go its the basic cheap corsair offer .I think if are unable to go gold atleat try to get bronze
Atleast
https://www.amazon.com/MasterWatt-Semifanless-Modular-Certified-Computers/dp/B074ZDLGMK/ref=mp_s_a_1_4?dchild=1&keywords=550w+psu+bronze&qid=1588175445&sr=8-4
I recommended
https://www.amazon.com/Seasonic-S12III-SSR-550GB3-Control-Warranty/dp/B07MWGZT5N/ref=mp_s_a_1_5?dchild=1&keywords=550w+psu+bronze&qid=1588175445&sr=8-5
https://linustechtips.com/topic/1186074-need-help-choosing-psu/#findComment-13540580
