Hi. I bought a new power supply recently and ever since then my computer no longer goes into sleep mode. I can click it manually but it's just nice to have it go to sleep automatically. I checked in power options and it says "Put computer to sleep after 20 minutes" but doesn't work. Any idea's?
Intel i7 3770K [] Asrock Z77 Extreme 4 [] MSI R9 290X 4GB [] 16GB  G.SKILL 2133Mhz [] Crucial MX100 256GB [] WD Black 1TB [] XFX Pro 850W [] Fractal Define R3 [] Func MS-3 R2 [] Corsair K60 []
https://linustechtips.com/topic/118603-problem-with-sleep-mode/
Go into device manager and select network adapters. Find your network adapter, then once you select that go to power options and uncheck "Wake on magic packet" and the other options below it. It could be your network adapter that's waking up your PC.
I had this problem recently but when I'd put it to sleep manually it would still wake up. This was the solution.
https://linustechtips.com/topic/118603-problem-with-sleep-mode/#findComment-1581760
Thanks but unfortunately "Only allow magic packet to wake the computer" was already unchecked =\
https://linustechtips.com/topic/118603-problem-with-sleep-mode/#findComment-1581831
It is magic, it can be checked even if it isnt...Mysterious... xD
|OscillosC Build|+ Raspberry Pi [NAS] + Another G5 + Personal + HTPC: Asus Z87-A - Intel Core i5 4670K @ 4.5ghz 1.15v - Noctua NH-D14 - Gigabyte Radeon HD7870 OC @ 1170mhz core- Kingston HyperX 8gb 1600mhz CL9 - Samsung 840 PRO 128Gb SSD for Windows- Kingston V300 120gb for Ubuntu- WD Caviar Black 1Tb For games and programs - WD Caviar Green 2Tb For videos, photos, music, and backups- Seasonic P660 XP2 Platinum - Windows 8.1 PRO - Ubuntu 14.04 - Modded Bitfenix Ghost
https://linustechtips.com/topic/118603-problem-with-sleep-mode/#findComment-1582847
