Headphone PC Issue
Go to solution Solved by The Flying Sloth,
1 minute ago, OzzoCore said:
Oh okk, does that mean mic will be overall improved because it’s very good on phone.
It will perform the same on your PC as it will on your phone.
Hi, I didn’t exactly know which forum or where to post this but it was pc related so I thought I can use some help.
I have a pair of skull candy hesh 3 headphones and when I plug a TRRS 4 pin audio aux cable into the combo jack in my pc, control panel picks the mic and headphones up but playback through headphones and the mic isreally quiet. If I were to buy a bluetooth dongle for my pc and connect my headphones via bluetooth would this solve the issue?
https://linustechtips.com/topic/1185743-headphone-pc-issue/
I mean, if the bluetooth in the headphones sounds good enough for you from your phone it will sound the same from your computer.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
https://linustechtips.com/topic/1185743-headphone-pc-issue/#findComment-13537996
It’s not necessarily how good the sound is it’s just that the headphone and mic is so quiet. Do you mind explaining what you mean a little more, I’m a bit confused?
https://linustechtips.com/topic/1185743-headphone-pc-issue/#findComment-13538005
Volume over bluetooth is controlled by the amplifier housed within the headphones, it will be just as loud as it is with your phone.
@rice guru
https://linustechtips.com/topic/1185743-headphone-pc-issue/#findComment-13538019
I think I kind of understand, so will using bluetooth be louder than a wired aux on my PC? Sound through bluetooth is pretty loud on phone.
https://linustechtips.com/topic/1185743-headphone-pc-issue/#findComment-13538023
It will be just as loud on your PC as it is with your Phone
@rice guru
https://linustechtips.com/topic/1185743-headphone-pc-issue/#findComment-13538046
@rice guru
https://linustechtips.com/topic/1185743-headphone-pc-issue/#findComment-13538109
