1. Budget & Location
Budget- $850.00, location Missouri USA
2. Aim
Mostly gaming such as diablo 3 while using spotify and chrome at the same time. Wishing to get into playing more new PC games that I've never had the hardware for.
3. Monitors
I use an Acer model-H236HL, 1080p currently.
4. Peripherals
I'll need windows 10 as well as a case no bigger than 9in. Wide and 18in. Tall. I won't need a keyboard or mouse or anything. I'd like some USB ports in the front on the tower as well as the back.
I'd like an SSD at least for windows if at all possible. I won't be needing wifi.
5. Why are you upgrading?
I've been wanting to build a PC for years, I now have the money to do so.
had to repost due to time past from first post and out of stock items.
https://linustechtips.com/topic/1185511-first-build-85000/
Or if you want a ryzen 5 3600:
Quote me or mention me at @Shrekpad so I get notified
pc specs:
CPU:
Intel i7 8700K MOBO: ROG Strix Z390-E Gaming RAM: 16GB (2x8) DDR4 G Skill TridentZ 3000 MHz GPU: Gigabyte GeForce RTX 2080 SUPER GAMING OC CASE: Phanteks Enthoo Evolv STORAGE: Sabrent Rocket Q 1TB M.2 NVME SSD,
T-Force Delta RGB 250GB SSD, 4TB Seagate Barracuda HDD PSU: 750 Watt EVGA SuperNova G3 MONITERDell S2716DGR 1440p 144hz G-Sync, BenQ PD2700U 4K 60hz CPU COOLER: Corsair H115i RGB Platinum OS: Windows 10
https://linustechtips.com/topic/1185511-first-build-85000/#findComment-13536276
I don't know what the ryzen 5 3600 would provide. I'm guessing a larger SSD would jack the price up huh?
https://linustechtips.com/topic/1185511-first-build-85000/#findComment-13536300
Ryzen 3600 provides better clock speed, more cores/threads, 7nm process, etc.
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
https://linustechtips.com/topic/1185511-first-build-85000/#findComment-13536311
6 minutes ago, Shrekpad said:
If @Murder Crow777 went with this... well that is on over priced 1600 AF. I would wait for 3300X. Better price/perfomence for $5 cheaper.
ltt meme thread
pc:
SSD: 256GB SP
OS: Windows 10
Status: Main PC
-wall03
https://linustechtips.com/topic/1185511-first-build-85000/#findComment-13536315
It’s a 4 core 8 thread processor, 2 more cores and 4 more threads is definitely worth it. Altough the ryzen 5 1600af is quite overpriced at the moment.
pc specs:
CPU:
https://linustechtips.com/topic/1185511-first-build-85000/#findComment-13536331
right. Forgot to factor that in.... yes it is very overpriced.
ltt meme thread
pc:
SSD: 256GB SP
OS: Windows 10
Status: Main PC
-wall03
https://linustechtips.com/topic/1185511-first-build-85000/#findComment-13536341
3 minutes ago, Murder Crow777 said:
when does the 3300X come out?
It comes out May 21st
ltt meme thread
pc:
SSD: 256GB SP
OS: Windows 10
Status: Main PC
-wall03
https://linustechtips.com/topic/1185511-first-build-85000/#findComment-13536342
Uhhh what? The 3600 has the same cores and threads as the 1600.
2 more cores and 4 more threads than what? No one suggested a 4 core CPU here.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1185511-first-build-85000/#findComment-13536371
I was coomparing it to 6/12 processor (3600)
16 minutes ago, Murder Crow777 said:
that sucks, i was hoping to buy everything today
Well then don't buy it
ltt meme thread
pc:
SSD: 256GB SP
OS: Windows 10
Status: Main PC
-wall03
https://linustechtips.com/topic/1185511-first-build-85000/#findComment-13536419
