Basically I game on both pc’s.
I port forwarded my main pc and it’s fine. But the other is still moderate.
When I go in the route and setup the ports, I have to assign a pc(ip) with them.
So I can’t add the same port and assign it to another pc because it tells me I already have that port opened.
So isn’t there another type of forward I’m supposed to do to fix this. I’m not sure it will allow me to forward the port with assigning a pc. I guess that’s the main issue.
The router is an Asus Rt-Ac66r.
pfa
https://linustechtips.com/topic/1185453-multi-pc-port-forwarding/
Why are you port forwarding? Port forwarding is for allowing outside connections access to a port on your PC despite being behind a router, you don't need to do that to play games.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
I do when nat is strict or moderate. It is needed. Or else I wouldn’t be doing it.
Alright then. But to answer your question, you can't assign the same port to forward to two different destinations, so you need to use different ports for each computer.
¯\_(ツ)_/¯
Desktop:
Laptop:
As above you can't forward the same port to multiple destinations.
UPNP usually resolves this by dynamically opening different ports for each PC but it largely depends on the game.  You'd also want to make sure UPNP doesn't listen on the WAN interface by doing something similar to the 'GRC ShieldsUp UPNP Exposure Test'
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
Just trying to play the new cod. From what I’ve seen it’s the same info as all the others.
