Hello!
Can i pair a set of Earbuds with my PC (i have bluetooth)
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1185446-bluetooth-handsfree-earbud/
5 minutes ago, Constantin said:
Hello!
Yea, you just follow the instructions given by the earbuds and on your PC go to Settings > Device > Add Bluetooth or other device > Bluetooth and choose your earbuds
Yes but when i remove them from the case they automatically connect to the phone .......
Reset the earbuds and connect them to your PC and back to your phone later or consult the manual to see if you can connect it to multiple devices.
