This is the power supply I have: https://www.bhphotovideo.com/c/product/1012719-REG/evga_120_g2_1300_xr_supernova_1300_g2_power.html/specs
I'm trying to find a case with a shroud, some rgb, and temper glass paneling that can house this power supply but I'm confused about how the measuring system
works. So my PSU dimensions are: 85mm x 150mm x 200mm  and most cases just state can fit 160mm power supply well thats if they state anything at all.
New to PC building any helpful pointers or tips to help me pick a case making my first build memorable and painless would be highly appreciated.
Also for any suggestions I'd like to keep my price range around $150 to $200 and extra points for cheaper lol
https://linustechtips.com/topic/1185245-need-help-choosing-a-case/
I think p400a fits
Quote me for a reply, React if I was helpful, informative, or funny
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
My memory is a LTE power supplies are standardized by height and width, and fan hole location.  This one is merely a bit long.  I suspect that nearly any bottom mount would be fine, excepting SFF stuff.
