I purchased a used i7 4790 to upgrade the i3 4170 in my ASRock H97 MITX motherboard. With the i7 installed, my system will not post, but the lights/fans will come on. I have updated the BIOS to the latest revision, and cleared the CMOS. I assume that if the 4790 was bad, the system wouldn't even power on.
Am I missing something, or do I need to return the CPU?
https://linustechtips.com/topic/1185185-system-wont-post-with-cpu-upgrade/
Depends on what part is bad.  Are you using the iGPU?
