Designing or buying a DP 1.2 USB Hub
Solved by AbydosOne,
8 hours ago, YouDontHaveToKnow said:usb hub with dp 1.2 aux standard
Just to be clear, you're referring to the DP Aux Channel Standard, and not the USB-C DP alt mode? (assuming the former)
I don't think there's any GPU support for USB (2.0) over the DP Aux channel. It looks like it's mostly used for EDID. You'd need to build an injector of some sort, and then an extractor on the other.
The most recent references I can find to anything approaching a product would be in 2010.
