I have had my ASUS PG248Q for a little over a year now and I just now came across an article saying I should have vsync on. I have always heard that vsync introduces input lag and it should not be used. Also, I read that you should cap your fps at 3 under the max for the screen. But I've also heard that uncapping your fps makes games more responsive because the gpu is adjusting the game quicker. Then there's the NULL. I've turned that to Ultra since getting a 9900k for Christmas. What would you say are the best settings for gsync? I want to take advantage of it because it feels like a waste not to. Thanks
The article I read was https://blurbusters.com/gsync/gsync101-input-lag-tests-and-settings/14/
https://linustechtips.com/topic/1184504-gsync-settings/
Also, fast vsync or just on?
https://linustechtips.com/topic/1184504-gsync-settings/#findComment-13528756
All other syncs off and fps set to the display Hz ingame.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/1184504-gsync-settings/#findComment-13528792
2 minutes ago, Coopermar said:
What about NULL?
Never used it. Dont know.
https://linustechtips.com/topic/1184504-gsync-settings/#findComment-13528851
Basically:
Shooters - all off to avoid any additional lag from any form of sync
All the rest - G-sync on + cap below max refresh rate to always have FPS in G-Sync range and have nice smooth image.
Overall Gsync does not add that much lag (from what I have read over the years and from personal experience) therefore, you can leave it on for most shooters as well.
As for NULL, based on Nvidia you should always have it on to reduce latency for games where fps is between 60-100, but I personally never used it, maybe others have opinion and personal experience on that.
At the end, use what you feel comfortable with :)
https://linustechtips.com/topic/1184504-gsync-settings/#findComment-13531181
50 minutes ago, Envit0 said:
Basically:
Gsync shines in shooters. There is no lag caused be Gsync.
https://linustechtips.com/topic/1184504-gsync-settings/#findComment-13531366
