Alright guys so long story short my ancient mobo died on me a couple weeks ago and I've been trying to figure out what to do. I see no point in buying old hardware to replace the mobo since its DDR3 ram and 1150 socket with an i5 4950. So that leads me to an upgrading mobo, cpu, and ram. I would like to upgrade those components within $600.00.
The stuff I'm hoping to carry over would be my current graphics card (msi gtx 1060 6 gig), a 1 TB sata and a 250 GB SSD. I have a Pallas 120 cpu cooler (new) a 700 watt Thermaltake PSU (new) and an NZXT H510 case as well that I would probably use.
So assuming that my 1060 isn't too out of date I'd like to sink the money into mobo, cpu, and ram. Ideally I would like to game and stream (720p is fine) on it however most of the time I'll just be gaming on it. Let's see some games I would play would be Skyrim, Battlefield 4, Sea of Thieves, Guild Wars 2, CoD War zone, CSGO, maybe PUBG. Of course id like to future proof it a little bit if possible. My last build went about 7 years with just a gpu and drive upgrades I believe and I'm very happy with that.
I've done some research and it really seems like AMD is the way to go right now. I was thinking about going with the 3700x and the MSI B450 tomahawk atx mobo and G.Skill Ripjaws V 32 GB (4 x 8 GB) DDR4-3600 Memory.
https://pcpartpicker.com/user/Jmilligan/saved/tFmBcf
What are your thoughts 🤔?
https://linustechtips.com/topic/1184451-desktop-build-advice/
you can buy a new gpu later this year.
PCPartPicker Part List
Type Item Price
CPU AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor $294.14 @ Amazon
Motherboard MSI B450 TOMAHAWK MAX ATX AM4 Motherboard $114.99 @ Best Buy
Memory G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3600 Memory $159.99 @ Amazon
  Prices include shipping, taxes, rebates, and discounts
  Total $569.12
  Generated by PCPartPicker 2020-04-26 13:19 EDT-0400
2x sticks of ram is always better than 4 sticks. less load on the memory controller, easier to overclock etc.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1184451-desktop-build-advice/#findComment-13528285
if you are only gaming there is little to no point in getting anything other than a 3600, unless you go for a 3950x.
there are nearly any fps gains.
also, stricktly for gaming you do not need 32 GB of ram.
the mobo is good
id go for something like this:
if you can manage to sell your 1060 you could even fit a 2060 in that budget
EDIT:
if you are willing to go used for a gpu you could even get a 2070
My Rig / Buildlogs:  ❄️ SNOWFLAKE ❄️ FROSTBITE ❄️
CPU: Ryzen 5 3600   Cooler: Corsair H115i Platinum   RAM: Corsair Vengence RGB Pro 16GB @3200   Mobo: Asus Prime X470 Pro
Graphics Card: Gigabyte Aorus 2080super Waterforce    Case: Corsair 500D   PSU: Corsair HX850i
Storage: 500GB Crucial P1 NVMe SSD, 1TB Crucial P1 NVMe SSD, 2x 1TB SATA SSD
Displays: AOC CQ32G1 32" 2560x1440, Acer XB280HK 28.0" 3840x2160 60 Hz, Medion MD20850 24" 2560x1440
https://linustechtips.com/topic/1184451-desktop-build-advice/#findComment-13528356
the mobo is good
EDIT:
I would like to stream. Do you think the 3600 can stream while I play? Typically I play 1080p. I think I will upgrade my video card later this year.
https://linustechtips.com/topic/1184451-desktop-build-advice/#findComment-13528656
YEs a 3600 can stream while you play. No point to not use nvenc though
https://linustechtips.com/topic/1184451-desktop-build-advice/#findComment-13528671
