I have an old dell optiplex 360 I am currently looking for a vertical GPU mount mod that will work on the case for using semi full size gpus I want to move my current system into the case with minimal use of a saw and other not too fun to use by hand tools to mod this so anything helps im getting a new rtx 2060 oc soon it's a dual fan design so it'll fit just gotta find the right adapter thank you very much in advance
You want to fit a new enthusiast GPU in an old business case and you don’t want to do any cutting.  There are other problems you may want to look at (you may have already done so). PSU compatibility is a big big one.  Both cables and power output.
you may be better served with a new case depending on price.  Modding probably isn’t impossible but requires time tools and materials.
I'm kinda stuck on an extremely tight budget atm otherwise I would buy a new case. Also minimal cutting I'll be drilling new mounting holes for the Mobo and cutting off the old Mobo panel and a mounting area for my fan and rad. I already have everything figured out when it comes to that. the biggest thing is mounting the gpu I know there are brackets but don't know which ones will fit. Sorry I didn't get all the details in the main question, I didn't think to mention it til you brought it up
Edited by Jc115555
Forgot details in original post
