Fastest speed you can, TP Link.
Although i would recommend powerline over WI-FI
System: 5930K, MSI X99 SLI PLUS, GTX 780Ti (SLI),  840 EVO, Fractal R4 (Full Custom Loop)  (IP)
Media Server/Perm Folder: i3 4130, CX500, 4 X WD Red 1TB, 60GB Adata SSD for boot, Node 304, ASrock Z87-E ITX, 8GB Kingston Value Ram
Need more info.
What Wi-Fi standard does your router use?
Are you looking for a USB adapter? Or a PCI card?
Preemptive suggestion:
I have an Intel Dual Band Wireless-AC 7260 plus Bluetooth Adapter
US Amazon
Currently $50USD on Amazon
Awesome piece of hardware and is PnP at least on Windows 8.
One thing to note however, there is a problem in one of the batches that makes bluetooth not work. Problem and solution noted here: Intel Forums
PC Noise Hater Level = Linus
