Hey Gamers, and PC enthusiasts, I need some help, can I run 3600 speed ram, with my ryzen 7 2700, is there a way to do so? because what i have researched, it caps at like 2933 speed for my cpu, or do I just need a new cpu. (Im using asus prime b450 m-a mobo and rx 580 card) Ram: OLOy Warhawk 32 gbs 3600 mhz
https://linustechtips.com/topic/1184162-help-me-pls/
You can't. And the motherboard doesn't support faster ram either. And If youre gaming remember the GPU is a lot more important than the CPU and i'd recommended it be at least 1.5x more expensive then the CPU, more like 2x generally
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
https://linustechtips.com/topic/1184162-help-me-pls/#findComment-13526398
