Overclockig monitor
Marinos Karp
is it okay if i Overclock my Laptops monitor. Is there anything that i should know of?
no it should be fine, monitor quality depends on the amount you can go by, i had a 60hz monitor and at 1080 i can go to 67hz, not much but make a noticeable difference in games, due a upgrade soon but thought id share my thoughts
Okay  Thanks! I was wondering because i read some article saying it can damage the monitor and though i should ask!
  • 2 weeks later...
you can do it! but battery-life would decrease and you wont go higher than 70hz
