Zero fucking idea what I just read.
Are you asking for a fingerprint scanner of some sort? What is it unlocking? There are locks with built-in FP scanners.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
Quote
My wife and I watch your youtube videos. I want to add a fingerprint sensor to my shed but I don't know how, can you please help?
Most hardware stores will sell off the shelf locks that have built in fingerprint sensors. Pretty much the same as installing a regular lock. If your shed is already using a bolt or hinge latch that is secured with a padlock then you can just buy an electronic padlock with a fingerprint sensor and use that instead of a regular padlock.
Keep in mind that most finger print locks are laughably insecure, so don't use a fingerprint lock if there's anything in the shed you don't want to lose (expensive tools, motorbike, etc).
