7 minutes ago, GT1986 said:
Hi guys, I was looking through the forums and I am wondering in which forum should I ask questions about VPN. Thanks a lot for the help
This one will do, what's your question?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1182666-looking-for-vpn-help/#findComment-13516364
I am looking for a good VPN that allows me to watch movies on popcorn time with no security issues and here and there watching American Netflix. I check some VPN providers and I came up with 5 that seems good: NordVPN, ExpressVPN, CyberGhost, Surfshark and Zenmate. I am hoping you guys could narrow it down and tell me which one you recommend
https://linustechtips.com/topic/1182666-looking-for-vpn-help/#findComment-13516369
ExpressVPN would be my recommend, its the only one I know of (and actively use) which will help you if you complain to them when netflix reports the use of VPN, it also has apps for my smart TV which means its easier.
ICT professional, Addicted to PC
https://linustechtips.com/topic/1182666-looking-for-vpn-help/#findComment-13516374
-= Topic moved to Programs, Apps and Websites =-
I've been using PIA for my desktop for about 5-6 years with no issues.
I've have also been using 1.1.1.1 on my Android phone now for almost 2 years, pretty nice.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1182666-looking-for-vpn-help/#findComment-13516400
https://thatoneprivacysite.net/
https://linustechtips.com/topic/1182666-looking-for-vpn-help/#findComment-13516445
