I have a Ryzen 5 1600 AF and I OC it to 3.9 ghz on stock cooler and without changing the voltage which is at 1.2 stock. And after running the stress test I noticed that my temps across all cores are still 66 which they were under stress before oc. Is that supposed to happen?. I expected them to jump to the 70-75 range but no. Also how long should i run the test and if all is good should I try to increase the OC to 4 ghz or even more? that would be crazy considering the fact that am on stock cooler/thermal paste and still at 66c temp. BTW stress program is Prime95 using large FFts and monitoring using HWMonitor and coretemp.
https://linustechtips.com/topic/1182542-same-temps-after-oc/
if you havent changed the voltage then you arent applying any more power, thats what heats the CPU up. your all good, youve netted yourselfsome free Mhz at no cost...:)
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/1182542-same-temps-after-oc/#findComment-13515563
Just now, X3R4VY said:
Thx for the reply. Should I try and go for 4 or 4.1?
Sure, its not going to halm anything, you may find you need to up the voltage which is when you will see a increase in temps
1
https://linustechtips.com/topic/1182542-same-temps-after-oc/#findComment-13515568
