I NEED HELP!
Barbsxx365
I bought a AOC monitor a couple days ago, the 24V2Q and for some reason it gives me these weird pixel patterns on the screen. Also sometimes I have little lines of purple which are very weird.  Is the monitor damaged? Should I send it back? HELP
(The pixels appear when a move my mouse, they go away once I move my mouse again)
Try different ports and cables
Desktop benching:
Firstly, make sure you are running at the monitor's native resolution and refresh rate. If both of those are true, then try a different cable and/or input. Lastly, you could connect it to another PC to make sure it isn't an issue with your GPU. If all of that fails, you may need to RMA it.
Primary Gaming Rig:
Ryzen 5 5600 CPU, Gigabyte B450 I AORUS PRO WIFI mITX motherboard, PNY XLR8 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 500GB SSD (boot), Corsair Force 3 480GB SSD (games), XFX RX 5700 8GB GPU, Fractal Design Node 202 HTPC Case, Corsair SF 450 W 80+ Gold SFX PSU, Windows 11 Pro, Dell S2719DGF 27.0" 2560x1440 155 Hz Monitor, Corsair K68 RGB Wired Gaming Keyboard (MX Brown), Logitech G900 CHAOS SPECTRUM Wireless Mouse, Logitech G533 Headset
HTPC/Gaming Rig:
Ryzen 7 3700X CPU, ASRock B450M Pro4 mATX Motherboard, ADATA XPG GAMMIX D20 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 1TB SSD (boot), 2x Seagate BarraCuda 1 TB 3.5" HDD (data), Seagate BarraCuda 4 TB 3.5" HDD (DVR), PowerColor RX VEGA 56 8GB GPU, Fractal Design Node 804 mATX Case, Cooler Master MasterWatt 550 W 80+ Bronze Semi-modular ATX PSU, Silverstone SST-SOB02 Blu-Ray Writer, Windows 11 Pro, Logitech K400 Plus Keyboard, Corsair K63 Lapboard Combo (MX Red w/Blue LED), Logitech G603 Wireless Mouse, Kingston HyperX Cloud Stinger Headset, HAUPPAUGE WinTV-quadHD TV Tuner, Samsung 65RU9000 TV
Sadly I already tried with all my HDMI and display port cables. Nothing, the problem keeps persisting!
Other monitor shows the same thing or not?
Desktop benching:
I am the only one who has a tower so only have this one. Will a Tv work?
Yeah I did all of that, except i am the only one with a tower in my house so, I tried plugging in my laptop and, it didn't do it.
Yes
Desktop benching:
13 minutes ago, Jurrunio said:
Yes
Yeah the problem also appears on the tv. That means it is the gpu right?
yup
Desktop benching:
I built this pc last week, it would really suck if it was a GPU problem :(((((
12 minutes ago, Jurrunio said:
yup
Great that is just what I needed. Do I need to rma it? or can I fix this myself do you think?
I doubt it's something you could fix, usually its bad video memory and that means dealing with soldering
Desktop benching:
Could it be something else? Like cpu or even the mobo?
I have not seen such case yet, it's always the GPU after testing with different monitors and cables.
Desktop benching:
Well thank you so much for your help! Last question what is this problem called?
artifacting
Desktop benching:
