Capture Card
Is is possible to get a decent pc free capture card for under $50usd?? I am planning to use it with a nintendo switch. All I reqiure is 1080p and 60fps. Please tell me if anyone can find one that is well rated.
https://linustechtips.com/topic/1181258-capture-card/
That depends on what you want out of it. if you are just trying to do 1080p 30fps im sure you can find something on amazon for under $50. if you want 4k/60 or 1440p/60 though than I think you are out of luck for that budget
If your question is answered, mark it so.  | It's probably just coil whine, and it is probably just fine |   LTT Movie Club!
Read the docs. If they don't exist, write them. | Professional Thread Derailer
Desktop: i7-8700K, RTX 2080, 16G 3200Mhz, EndeavourOS(host), win10 (VFIO), Fedora(VFIO)
Server: ryzen 9 5900x, GTX 970, 64G 3200Mhz, Unraid.
https://linustechtips.com/topic/1181258-capture-card/#findComment-13506138
It's hard to get 1080p60 capture cards for under $50 unless you strike a good deal on something like an Elgato HD60 of some sort or an AVerMedia Live Gamer Pro.
If you're using OBS and deinterlacing 1080i content to 60fps would suffice, you'd have a far easier time going that route.
https://linustechtips.com/topic/1181258-capture-card/#findComment-13506495
2 hours ago, turtlecraft said:
Is is possible to get a decent pc free capture card for under $50?? I am planning to use it with a nintendo switch. All I reqiure is 1080p and 60fps. Please tell me if anyone can find one that is well rated.
$50 usd ?
CPU - I9 10900 | CPU Cooler - Corsair Hydro Series H100x AIO | Motherboard -  Aorus B460 PRO AC | RAM -G.SKILL Ripjaw V series 4x8GB 2666MHZ | Graphics Card - Gigabyte RTX 3070  | Power Supply - Cooler Master 650w  | Storage -  Working on a new Spicy
Operating System - Windows 10 Pro
https://linustechtips.com/topic/1181258-capture-card/#findComment-13506507
