Hi,
     I want to water cool my computer that im going to build for my collage class but i dont know what, where and how much to buy. If you could help me out I would be very grateful.
here is a list of specs
Intel Core i7-4770k cpu
2 Asus Geforce GTX 780 Ti 3GB Video card
Asus Maximus VI Extreme Atx LGA1150 Motherboard
Corsair Vengeance Pro 16Gn (2 X 8GB) DDR3-24000 (I might put another 16GB in it just for fun)
Intel 530 240Gb 2.5" SSD
3 3TB 3.5" Seagate Barracuda HDD
Corsair 1200W   80= Platinum Certified Fully Modular ATX Power Supply
I would like to put 2 of the 3 Hard Drives in to a Raid Array but i dont know hat raid and what a good Raid Card is.. so if you know then will you please let me know.
i mught put a sound card in it too but im not sure
It will have WiFi card but i dont know what one to get right now over even if i should get one because the motherboard has one that it comes with but im not sure how good of a card it is.
It might end up have a wired Network card if the teacher doesnt let me use the stander ports on the motherboard.
The Case will be picked out around how meany radiators and the size of them
If there is anything else you would suggest me puting in this cimputer then let me know.
"War,war never change"
https://linustechtips.com/topic/118108-need-advice-please/
Hi,
most motherboards support a raid array these days from raid 0,1,5,10 - raid 0 being fastest but least reliable needing 2 drives, raid 10 being fast and reliable (4 drives i THINK), raid 5 for reliability needing 3 drives.
The Beast [Case -  Corsair 750D CPU - I5 4670k @ 4.3ghz 1.2V CPU cooler - Hyper 212 evo Mobo - MSI g45 z87 RAM - G.Skill Z series 4*4@1866mhz GPU - Gigabyte windforce 3x r9 290 Storage - SSD, samsung 840 evo 120gb HDD, Western Digital Blue 1tb PSU - SilverStone Strider silver 80+ 750WPeripherals [Monitor - ASUS VS239 IPS 23" Keyboard - Corsair K95 Mouse - Mad Catz RAT 7]
https://linustechtips.com/topic/118108-need-advice-please/#findComment-1575484
Any reason you need 2 780ti's? Also you don't really need to RAID, JBOD will be fine but if you do want to your motherboard will let you do it.
https://linustechtips.com/topic/118108-need-advice-please/#findComment-1575511
What is this peasant build? You need an Intel Celeron.
JK
But I'm pretty sure you should invest in a Wireless card or read the Network Policy of the college you're going to. It might be good to have a wireless card just to make sure you can connect to the network.
https://linustechtips.com/topic/118108-need-advice-please/#findComment-1575534
see italics
collage college
Intel Core i7-4770k cpu i5 is fine really, unless you're doing more than gaming and actually do work on your PC
2 Asus Geforce GTX 780 Ti 3GB Video card go with one for now, two is a bit excessive for anything short of surround or 4k
Asus Maximus VI Extreme Atx LGA1150 Motherboard not the best use of money, but ok
Intel 530 240Gb 2.5" SSD I would just get one of Samsung's Pro SSD's, the software that comes with it is amazing in addition to solid performance
3 3TB 3.5" Seagate Barracuda HDD ok
Corsair 1200W   80= Platinum Certified Fully Modular ATX Power Supply 850w, 1000w at most is all you would need if you're not going enthusiast socket
i mught put a sound card in it too but im not sure no. unless you're doing music production, then you would want an interface card anyway
It will have WiFi card but i dont know what one to get right now over even if i should get one because the motherboard has one that it comes with but im not sure how good of a card it is. If the motherboard comes with it, don't bother, it will be fine.
The Case will be picked out around how meany radiators and the size of them pick case first, then radiators, not the other way around.
Error: 410
https://linustechtips.com/topic/118108-need-advice-please/#findComment-1575559
lets get the hardware worked out before touching the water cooling aspect of the build.
@FallemC Please read: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/
https://linustechtips.com/topic/118108-need-advice-please/#findComment-1576650
The on-board Intel wired LAN port and dual channel 2.4/5GHz WiFi 802.11 a/b/g/n/ac should handle any network you are likely to encounter. Unless you have a requirement that is only met by a feature on a particular sound card buying one is a waste. The on-board sound quite good.
Use the on-board Intel RAID for a RAID 1 array. I'd suggest a 1TB ssd and do away with the 3rd hdd.
I've suggested a case, the soon to be released Graphite 760T.
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU:  Intel Core i7-4770K 3.5GHz Quad-Core Processor  ($279.99 @ Amazon)
Motherboard:  Asus Maximus VI Extreme ATX LGA1150 Motherboard  ($376.99 @ SuperBiiz)
Memory:  Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-2400 Memory  ($241.20 @ NCIX US)
Storage:  Samsung EVO 1TB 2.5" Solid State Disk  ($499.00 @ Amazon)
Storage:  Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($100.00 @ NCIX US)
Video Card:  Asus GeForce GTX 780 Ti 3GB Video Card (2-Way SLI)  ($699.99 @ NCIX US)
Power Supply:  Corsair 1200W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($319.99 @ Microcenter)
Other: Corsair Graphite Series 760T White Steel / Plastic ATX Full Tower Windowed Gaming Case with two 140mm red LED fans  ($205.00)
Total: $3522.15
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-02-20 01:11 EST-0500)
https://linustechtips.com/topic/118108-need-advice-please/#findComment-1576744
