Hi All!
Recently joined the forum, thought I would share with you my current and first ever machine that I built!
It was great fun after watching build guides for many months in preparation. After getting a sizeable tax return I thought there was no better time to get into the PC gaming scene.
The specs are as follows:
CPU: AMD Ryzen 7 3700X 8C/16T @ 4.3GHz (All-Core)
GPU: Gigabyte NVIDIA GeForce RTX 2070 Super Gaming OC (+125/750)
Motherboard: MSI X570 Gaming Edge Wifi
RAM: 32GB (4x 8GB) G.Skill Trident Z RGB DDR4 3466MHz (OC)
Cooling: Silverstone PF-360 ARGB Liquid AIO
PSU: Corsair RM650x (80+ Gold Modular)
Storage (1): Adata SX6000 Pro NVME SSD 512GB
Storage (2): Samsung 860 EVO 2TB SATA III SSD
Case: Cooler Master H500P Mesh White
It is paired up to an MSI Optix MAG271CQR (1440p, 144HZ, 1ms) display. My peripherals are a Corsair K70 MK.2 Keyboard (Cherry MX. Blue), Gamescom Plantronics 780 Headset and Logitech G502 Hero wired mouse.
I like to play a fair bit of Assetto Corsa, so I have set up a full Logitech G920 Wheel, pedals and shifter also.
Let me know what you think, Cheers!
Harrison Allwood
https://linustechtips.com/topic/1180823-my-first-rig/
It's a bit difficult to see the rig so more pictures would be good!
I'd suggest keeping an eye on your GPU temps, whilst vertically mounted GPUs look so much better they can have issues with trying to suck in air from the window which has very little.
Yours doesn't seem to be too close to it (but its difficult to tell) which might be fine, I know others have seen performance dips due to the above but I haven't aircooled a vertical GPU.
https://linustechtips.com/topic/1180823-my-first-rig/#findComment-13502760
Thanks man! Its a bit tight in there I agree, however the temps seem to be ok. Destiny 2 & MW have the card at 60-65 degrees with a 60% fan curve, so i'm pretty happy.
https://linustechtips.com/topic/1180823-my-first-rig/#findComment-13502856
