Just now, UberInferno said:
i'm running my i7 3770k under load 85-90 degrees for around a month now, if i countinue long term, will it give up on me? shall i bring to at least 80 - 85?
Technically that is in spec and ok. But some believe that this will degrade the CPU a bit (make it last a bit less long) but I have never had or heard about a burned out chip (besides heavy OCing)
So why is it that hot? Big OC or crappy cooler?
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
https://linustechtips.com/topic/1180662-cpu-temperature/#findComment-13501449
sub 85 is a big improvement
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1180662-cpu-temperature/#findComment-13501453
4.6 ghz running botw all 8 threads 100%
using gd900 as thermal paste and tx3, however my tx3 cooler just seems as the pipes are clogged in a way? i've seen on internet better results with it
https://linustechtips.com/topic/1180662-cpu-temperature/#findComment-13501457
They cant be clogged. MAYBE and I guess not damaged so the gas leaked. But that wont be the case. Are you running the fan on a decent RPM?
Also I have never heard about that paste but yeha. Easiest thing is to remount and dust the cooler and see what happens.
If fan optimizations and repasting dont help it might be time for a bigger cooler
https://linustechtips.com/topic/1180662-cpu-temperature/#findComment-13501477
cooler was a bargain anyway, gd900 is a chinese paste the grade of mx5 for 1 buck lol, check techyescity comparison on thermal pastes, rpm is max at 2500, i'll see what else i can do
https://linustechtips.com/topic/1180662-cpu-temperature/#findComment-13501490
oh okay, isnt that a bit loud? If nothing helps maybe good old 212 evo or something along those lines?
https://linustechtips.com/topic/1180662-cpu-temperature/#findComment-13501508
