Links to the actual products' pages would be helpful but considering both are Cooler Master ARGB products I would assume yes.
CPU: Ryzen 3700X VGA: RX 5700 8G RAM: 32GB 3200MT/s DDR4 Motherboard: B450 Aorus Pro
Storage: 2x1TB Crucial P2, 1TB Crucial MX500, 36TB NAS Cooling: Custom Loop 360mm & 280mm
PSU: Super Flower Golden Green HX 650W Case: Phanteks Enthoo Luxe
https://linustechtips.com/topic/1180232-argb-splitter/#findComment-13498110
3 minutes ago, RusselTheMuscle said:
Can I connect theses pins to this pin? image.png.8e8264c80d66b30dc3dbd43b5d893529.pngimage.png.99f67f0423e63e9e5b8ca281a86dd584.png
I am not quite sure what exactly I am looking at so I don't know.
P.S.: You should quote people's message to make sure they get notified of replies.
https://linustechtips.com/topic/1180232-argb-splitter/#findComment-13498146
My problem is my case has 3 ARG fans and I am planning to add 3 more ARGB fans. But the included controller in the case only has support for the 3 included fans. So, I don't know how to put the splitter I showed in this post to the included controller of the case.
https://linustechtips.com/topic/1180232-argb-splitter/#findComment-13498163
Hmm... As long as you can find the header that fits with the aRGB splitter, it should be okay. However, I would caution you to be very careful as the power consume might overload your controller.
I have ASD (Autism Spectrum Disorder). More info: https://en.wikipedia.org/wiki/Autism_spectrum
I apologies if my comments or post offends you in any way, or if my rage got a little too far. I'll try my best to make my post as non-offensive as much as possible.
https://linustechtips.com/topic/1180232-argb-splitter/#findComment-13498450
