Recently I built a new system with the following parts, the set up went alright but i have a lingering issue i cant seem to fix. On fresh start up after the computer has sat for some time it'll boot up to have a laggy mouse movements, audio, games, etc., however if it runs for over an hour or the computer its restarted the problem goes away? Along with this while it is in its laggy state i try to shut down normally the screen will display shutting down then go dark while the system itself stays on until hard shutdown from the case? Any advice would be a big help
Ryzen 7 3700X Matisse 3.6GHz 8-Core AM4 Boxed Processor with Wraith Prism Cooler
1 of (SKU) 952036
X570 TUF Gaming Plus (WI-FI) AMD AM4 ATX Motherboard
1 of (SKU) 955807
GeForce RTX 2060 Super Advance ROG Strix Overclocked Triple-Fan 8GB GDDR6 PCIe 3.0 Video Card
1 of (SKU) 071035
H510 Elite Dual-Tempered Glass RGB ATX Mid-Tower Computer Case - Black
1 of (SKU) 966317
Trident Z RGB 32GB (2 x 16GB) DDR4-3200 PC4-25600 CL16 Dual Channel Desktop Memory Kit F4-3200C16D-32GTZR - Black
1 of (SKU) 989905
Black SN750 1TB SSD 3D V-NAND PCIe NVMe Gen 3 x 4 M.2 2280 Internal Solid State Drive
1 of (SKU) 944538
Blue Mainstream 2TB 5400RPM SATA III 6Gb/s 3.5" Internal Hard Drive
1 of (SKU) 622373
https://linustechtips.com/topic/1180110-lagging-issue-on-fresh-build/
I think I am going through the same exact issues as you, and the only components we have in common are the Ryzen 7 3700x and x570 TUF gaming plus mobo.  My mouse and audio start to stutter and lag like I am having internet connection issues but I know that is not the case.  I also have the same issue of shutting off my computer with the monitor turning off but everything else stays on.  Were you ever able to figure anything out it is driving me insane?
