look up the users manual, it will tell you exactly what plug goes to which pins. It will be the header which the connector is resting on, on the right of the two long headers.
Desktop benching:
https://linustechtips.com/topic/1179808-i-need-help/#findComment-13495096
They are front panel connectors for the power/reset button, activity lights.
Refer to the manual for where they go
https://download.asrock.com/Manual/N68-GS4 FX.pdf
See page 11, and number 16 in the list/mobo diagram
See page 21, System Panel Header diagram
Note: the colored wire is the positive and the white wire is the negative.
https://linustechtips.com/topic/1179808-i-need-help/#findComment-13495098
Looked at it for ages now and have got no we’re with it, makes no sense to me
https://linustechtips.com/topic/1179808-i-need-help/#findComment-13495153
