PCPartPicker Part List: https://au.pcpartpicker.com/list/wmpz9G
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($289.00 @ Shopping Express)
Motherboard: MSI B450M MORTAR MAX Micro ATX AM4 Motherboard  ($159.70 @ Device Deal)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory  ($151.80 @ Newegg Australia)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive  ($182.00 @ Skycomp Technology)
Video Card: Gigabyte GeForce RTX 2070 SUPER 8 GB GAMING OC Video Card  ($892.60 @ Device Deal)
Case: Phanteks Eclipse P300A Mesh ATX Mid Tower Case  ($99.00 @ PCCaseGear)
Power Supply: be quiet! Pure Power 11 600 W 80+ Gold Certified ATX Power Supply  ($139.00 @ PCCaseGear)
Total: $1913.10
Generated by PCPartPicker 2020-04-18 15:57 AEST+1000
These are the components i currently have in my cart and i want to add a Valve index to my purchase list. Would this system be able to run VR games consistently or would i be facing some fps issues?
https://linustechtips.com/topic/1179786-vr-ready-system/
I would do two things:
1- If you can get 32GB of RAM, I'd do that. I've seen Far Cry 5 hit 18GB of usage on my computer. And if you get a 3200MHz kit, it would help keep the price within reason:
https://www.newegg.com/g-skill-32gb-288-pin-ddr4-sdram/p/N82E16820232091?Description=ddr4 32gb&cm_re=ddr4_32gb-_-20-232-091-_-Product&quicklink=true
2- Unless you plan on playing HL:Alyx (Since it seems to be the only VR game worth playing outside of DCS or F1) right now as soon as you build it, I would get a cheaper video card like a 1660 Super or 5600XT, and buy a GeForce 3000 series card in August, along with a Valve Index. I know AU prices are alot different than U.S., but $900 for a 2070 to me seems like a terrible value to me.
Edited by Action_Johnson
Spelggliing bad real
Work Rigs - 2015 15" MBP | 2019 15" MBP | 2021 16" M1 Max MBP | Lenovo ThinkPad T490 |
AMD Ryzen 9 5900X  |  MSI B550 Gaming Plus  |  64GB G.SKILL 3200 CL16 4x8GB |  AMD Reference RX 6800  |  WD Black SN750 1TB NVMe  |  Corsair RM750  |  Corsair H115i RGB Pro XT  |  Corsair 4000D  |  Dell S2721DGF  |
Fun Rig - AMD Ryzen 5 5600X  |  MSI B550 Tomahawk  |  32GB G.SKILL 3600 CL16 4x8GB |  AMD Reference 6800XT  | Creative Sound Blaster Z  |  WD Black SN850 500GB NVMe  |  WD Black SN750 2TB NVMe  |  WD Blue 1TB SATA SSD  |  Corsair RM850x  |  Corsair H100i RGB Pro XT  |  Corsair 4000D  |  LG 27GP850  |
https://linustechtips.com/topic/1179786-vr-ready-system/#findComment-13494886
@Action_Johnson Brilliant, i'll take your advice and pick up 32GB of 3600MHz RAM.
In regards to the GPU the new GPUs would probably be out of my budget if i'm picking up the new ram. Would you say i should stick with a 2070S at 890$ or switch over to a gigabye radeon RX 5700 XT 8GB Gaming OC for 720$ the price difference is only about 170$ but is the performance much of an increase?
https://linustechtips.com/topic/1179786-vr-ready-system/#findComment-13494950
2070S should be faster than a 5700XT I would think?
https://linustechtips.com/topic/1179786-vr-ready-system/#findComment-13495018
