Help!!! Hello beautiful tech people! Im bringing an issue which i don't know if you ever experienced and i'm seeking for big HELP!!! I got a Floston Halo RGB Rainbow 3 pack fans today, with a package containing the 3 fans, 1 fan controller with a 4-pin molex going to PSU for power, a remote for the controller, one extension cable with 2-pins going inside the controller and 4-pin for the motherboard ( only 1-pin inside the head of the 4-pin) and a 5v with 3-pin for the rgb. First, i conected all 3 fans in order from 1 to 3 in the controller and the molex on the PSU power cable. All good by now, fans working properly, RGB working good, the remote working good as well with all the modes lightning effects. I also wanted to try to connect the extension sync cable to the motherboard to test and see how is doing with the MoBo. I connected de 4-pin fan cable coming from the controller in the sys_fan_2 4-pin connector and the 3-pin RGB in the d_led connector from the MoBo at 5V, fans and RGB also worked good, obviously i was not able to use the remote for the controller because it was synced with the MoBo. Here comes the issue: i have disconnected the MoBo sync cable from the MoBo because i wanted to set it back to control fans and RGB manually from the remote, when i did that, fans and RGB won't work anymore.....god damn, i dont think i have done nothing wrong!!! Now, to have the 3 fans working i have to let the controller connected the to the 4-pin from the MoBo, bad news is that the RGB don't work at all.....and i dont know what to do and PLEASE help me guys....i messaged the shop i buyed the fans from but they did not answered to me yet, i wanna consult this forum maybe i will find out a way what the problem is and maybe fix it.
I am waiting for your opinions.
Thank you so much!
https://linustechtips.com/topic/1179664-fan-rgb-controller-mb-sync-issue-help/
