Next time feel free to just post the permalink.
You'll need a 1xxx or 2xxx chip to boot and update the board. If you don't have one, you can contact AMD and they can send you a boot kit.
Or you could buy a much cheaper board like a pro-VDH MAX from MSI where it is already updated
I would suggest getting the msi b450 tomahawk as it has a bios flashback so if it doesn't come with the latest bios you can just flash it without having to install a cpu ram etc and its 10 dollars more. Though you need a functioning computer and a usb stick to do it.
Quote me for a reply, React if I was helpful, informative, or funny
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
