do you hava a gpu installed? What hdmi are you using? The one on the gpu or the motherboard?
Have you tried using another port and not hdmi?
How do you know if it runs fine if it does not output video? Or is it just the hdmi output that is not working?
I have a graphics card (XFX Radeon 580) installed. For hdmi there are two slots (in the motherboard and graphics card) that both use the standard A hdmi. Neither work. As for the other ports, I have not tried the dvi-d port because dvi does not connect to my monitor.
What is your config?
If You have dual channel memory try running with one stick.
I think one or more ram sticks is dead or not installed correctly or sometimes compatibility issues.Try googling if ur ram sticks are compatible or not
Hope it helps bro
