Monitor voltage help
Solved by Glenwing,
US uses 120 V standard, and 240 V for large appliances. Europe uses 230 V standard and sometimes 400 V 3-phase for large loads.
Voltage 100–240 V means it can take voltage anywhere within that range. European 230 V 50 Hz standard is supported, you can use an adapter or another cable.
6
Legendario1973 ·
Posted in Troubleshooting5 -
7
ian_one ·
Posted in Troubleshooting3 -
3
2
2
