Hello everyone,
I'm having an issue with my system.
 I was mix and matching hardware from two systems I have and a gpu laying around to make one giant system for folding at home.
I have two CPUs one being a ryzen 1200 and the other being a ryzen 2700X. I have two motherboards and a b350 Asus and a ASRock b450 both with the latest BIOS updates.
I've tried swapping graphics cards I've tried going down to one graphics card one stick of RAM and just the CPU on both motherboards. I've swapped then back and forth
I have power and fan spins but I cannot get a post screen out of any gpu i swapped the cooler back to stock amd still not getting a image out.
when I turn the system off the LED on my cooler and the fan on my GPU keep spinning untill I unplug the HDMI cable
I'm completely lost at this point
Has anyone ever seen this issue before?
Nick
https://linustechtips.com/topic/1177771-system-issue/
Currently set up as the ASRock b450 with the 2700x 8 GB ram and and GTX 660 just trying to get a screen took the battery out of the mobo to clear cmos waited 10 mins and put it back together as soon as the HDMI was plugged in the CPU cooler lit up hit power still no screen
https://linustechtips.com/topic/1177771-system-issue/#findComment-13479888
First try getting a screen without a graphics card installed.   If you can do that, you’ve isolated the problem to the graphics card or drivers.  (With a slim possibility of a motherboard or memory problem.)
Also, graphics cards need the proper monitor profiles.  So, it may be a driver problem with you graphics card.
https://linustechtips.com/topic/1177771-system-issue/#findComment-13479922
The ryzen 1200 and 2700x don't support onboard graphics I thought
https://linustechtips.com/topic/1177771-system-issue/#findComment-13479961
Yep, you’re right -sorry.
And I just now noticed that you’ve swapped out graphics cards.  And that you didn’t get post.
So, you’re stuck with doing something difficult and annoying.  Install the parts on the motherboard of your other machine because it could be that the motherboard died.  If the parts work on another motherboard, you’ve found your culprit.
https://linustechtips.com/topic/1177771-system-issue/#findComment-13480071
Ok so I have officially no clue I've swapped components to the Asus b350 board I have and it's boots the post green led but no display still  with every gpu that i own system was
Asus b350 strix
8gb of trident z rgb in first slot
AMD stock cooler and 2700x
Gpus used we're rx580, GTX 970, GTX 960, GTX 660
all gpus were then tested on my main rig and worked fine I have no clue
Tried both cous as well the 1200 and 2700x both went to green post led
So I'm officially lost
Can you crush anything in a ryzen CPU cause I followed the directions for the noctua cooler itbdid feel right but this all started with the swap to this cooler
https://linustechtips.com/topic/1177771-system-issue/#findComment-13481568
