I have two intake at the front and two exhaust, one rear and one top. My rear exhuast fan is making to much noise for my liking, and I was wondering if one 140mm top mounted exhaust is enough? I have tried decreasing the fanspeed, but my bios only let me increase the speed or turn the fan off. I have also tried SpeedFan but it does not detect my fans. I have this case: http://www.phanteks.com/Eclipse-P300-TemperedGlass.html
https://linustechtips.com/topic/1177716-pc-fan-cofig/
Is there an option to adjust the voltage of the fan? Mine doesnt allow it to manually adjust the speed. Only the voltage to increase or decrease the speed of the fans
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1177716-pc-fan-cofig/#findComment-13479352
So what you are saying is that if I decrease the voltage coming in to the fan, the fan speed will also go down?
https://linustechtips.com/topic/1177716-pc-fan-cofig/#findComment-13479357
Precisely
12v or 1200mv is max
7.2 or 720mv is min
CURRENT PC SPECS
https://linustechtips.com/topic/1177716-pc-fan-cofig/#findComment-13479381
Depending on what components you're running a single exhaust should be fine.
To add to what others have said... if your BIOS won't allow for voltage reduction or lowering of the speed you can also add a low-noise adapter inline with the fan cable to the motherboard. It's basically a resistor that steps down the voltage to the fan physically (rather than via software). That would allow you to slow the fan down without messing with the BIOS settings at all.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1177716-pc-fan-cofig/#findComment-13479775
