How to calculate PSU load?
13 minutes ago, nootnoot1277 said:Hey guys
Can anyone give me the proper way to calculate your psu requirements?
Just to clarify, I've been building for years and always gone for more than what I need within reason and chose sensibly but right now I'm building up a Shuttle 2003 retro gaming PC and need to get a PSU for it and being Flex ATX means I'm limited on PSU wattage without breaking the bank so im trying to figure out what my total load would be so I don't have to overspend for not reason. I've got a rough idea but just wanna clarify.
To my knowledge it's the TDP or each part combined but I'm not sure how much the mobo, hdd, odd consume.
Specs:
Athlon 64 3200+ (Clawhammer): 89w
Radeon 9550: can't find TDP anywhere but the 9600 supposedly is 12w so I'd guess it's around that?
2x 1gb DDR Dimms
1 x 7.2k rpm SATA drive
1 x ODD
Just totalling up the main components with the 9550 as 20w since I'm not certain what it draws, I'm coming up with 141w that's *including* a 30% overhead so I'm guessing once I add ram, mobo and drives it would be around 200w?
Am I close or totally wrong?
I had almost a identical setup with a Shuttle bare bones for my first HTPC and you're probably pretty close on your calculation but because the Flex ATX PSUs have such horrible cooling I would go with a 300 watt unit.
