I tried my hand at OCing my graphics card, i did just as the tutorial said, got up to 1390 from 1360 then pc froze. I restarted and tried again til I got to 1390 and the same thing happened again, so i just reverted everything back to normal, but i started getting blue screens, be it playing games or just browsing. While restarting, my pc sometimes opened up in the bios for no reason and even showed me an error from microsoft .net but i didn't get to read what it was about. I tried reinstalling W10 with the option to keep my files but i just got a message saying the installation failed. Does anyone have any suggestions?
https://linustechtips.com/topic/1177591-pc-keeps-blue-screening-need-help/
You don't have to OC app for the gpu to start/apply at startup right?
Bios at default too?
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
7 minutes ago, RobertGabriel said:
No and yes
Have you try DDU wipe for GPU?
I mean reinstalling windows is last resort.
3 hours ago, RobertGabriel said:
Ok, I just did, I guess I am now supposed to reinstall my drivers?
Yes, reinstall and then do no overclocking yet. See if you BSOD now.
Apparently it's a ssd issue somehow, because i wasn't able to install my windows on my ssd but now that i installed on my hdd everything is fine
Usually its the HDD. Good to hear everything working though.
