Help me
Go to solution Solved by Fasauceome,
2 minutes ago, Hip hop gnome said:
Hi
make sure you quote us so that we can see your responses
here is a price comparison based on just the parts:
If you are paying almost 500 quid for this PC, you are being robbed. Is this website your only option?
What ????
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1177396-help-me/#findComment-13476847
1 minute ago, Hip hop gnome said:
No, Fasauceome meant that the i3 9100f doesn’t have integrated graphics, it’s not an APU.
Quote me or mention me at @Shrekpad so I get notified
pc specs:
CPU:
Intel i7 8700K MOBO: ROG Strix Z390-E Gaming RAM: 16GB (2x8) DDR4 G Skill TridentZ 3000 MHz GPU: Gigabyte GeForce RTX 2080 SUPER GAMING OC CASE: Phanteks Enthoo Evolv STORAGE: Sabrent Rocket Q 1TB M.2 NVME SSD,
T-Force Delta RGB 250GB SSD, 4TB Seagate Barracuda HDD PSU: 750 Watt EVGA SuperNova G3 MONITERDell S2716DGR 1440p 144hz G-Sync, BenQ PD2700U 4K 60hz CPU COOLER: Corsair H115i RGB Platinum OS: Windows 10
https://linustechtips.com/topic/1177396-help-me/#findComment-13476867
Hi
Primary PC:
PSU tier list
https://linustechtips.com/topic/1177396-help-me/#findComment-13476878
No I sent the wrong link I sent the actual specs above
https://linustechtips.com/topic/1177396-help-me/#findComment-13477111
1 hour ago, Hip hop gnome said:
Intel i3 9100
intergrated graphics
Asus tif z370-plus
8gb Corsair vengeance 2400mhz
nzxt h510
1tb seagate baracuda
Corsair 550 vs series
that is the actual one I want
Still a rip-off. Like I pointed out, you're being upcharged on almost every part. Plus, the VS is a crappy PSU and there's not really a reason to get a Z series motherboard for an i3.
I went on the site and threw together a better config:
hope this link takes you to the right place
https://www.pcspecialist.co.uk/computers/amd-am4-home-office/
Edited by Fasauceome
Primary PC:
PSU tier list
https://linustechtips.com/topic/1177396-help-me/#findComment-13477122
Thank you for your help
https://linustechtips.com/topic/1177396-help-me/#findComment-13477190
3 hours ago, Hip hop gnome said:
Thats on the CPU side, not GPU. A good GPU is also required for gaming, not only cpu. Only game i could think of that would most likley run better on the i3 is minecraft, as it isnt gpu intesive and more cpu intesive.
https://linustechtips.com/topic/1177396-help-me/#findComment-13479151
Would the i3 be better if I got a gpu like a 1060
https://linustechtips.com/topic/1177396-help-me/#findComment-13479261
