I have corsair vengence 3200mhz 2x8 installed on pc and i wanted to add another 2x8 Vengence 3200mhz RGB.
will it work?
1) will it run on the system
2) is it ok to have 2x8 ram but another one is the RGB version of 2x8 with the same size, brand, and speed
https://linustechtips.com/topic/1177118-help/
will it work?
Yes it will run perfectly
BOLD not ITALIC
https://linustechtips.com/topic/1177118-help/#findComment-13475113
