Need help. Hell of BSODs
alexnt
Go to solution Solved by alexnt,
It turned out that cpu is faulty
I'm desperate. I installed windows again one week ago but nothing changed.
Memtest (dimms one by one) with no errors.
It gave bsod even in safe mode.
When i try to install linux mint, installer crashes all the time but maybe this is irrelevant.
Ryzen 3600
MSI Tomahawk B450 latest bios
Corsair 16gb 3200MHz
Sandra bench passed
Aida shows max 77
Realbench pass
Cinnebench pass
BSODs mostly on idling or semi-idling
This is happening for about 2 weeks
Minidumps Link: https://www.dropbox.com/s/1bxkkfrv27167mm/Minidump.rar?dl=0
Did you notice that your system time seems way off in the dump file?
Can you test out installing onto a different drive?
Man, if it gave BSOD even in Safemode or failed to install Linux my only suspect is RAM or IO errors.
Time changes when i restart from live linux to windows.
I will borrow a HDD to test.
How will I determine if it is IO errors?
1 minute ago, Applefreak said:
Run a surface scan on the drive with Sea Tools.
Windows is installed on ssd.
I'm trying to install linux on a HDD.
Sorry I didn't mention that before.
