I uploaded my PC specs. I was thinking about upgrading or buying AMD 3600x CPU and some motherboard for it. I would like to get a new motherboard and CPU and heard that this CPU is really good. I don't know is my graphic card bottlenecks right now or not to be honest. So yea I can't buy anything like $1000 or something. AMD 3600x CPU in my country is around $200 and to get like a motherboard with it, should I upgrade my ram to ddr4 too or mine is ok right now? Sorry, I'm a real noob about this so I need all of the help I can get from you guys :) So looking for the best value to money for gaming. My only thing that I would really like is to get good motherboard that I will probable be posible to upgrade into future without buying a new one. I can't upgrade this ASRock Z77M anymore as far as I know :D
https://linustechtips.com/topic/1176713-help-with-upgrading-my-pc/
PCPartPicker Part List
Type Item Price
CPU AMD Ryzen 5 1600 (14nm) 3.2 GHz 6-Core Processor $119.95 @ Amazon
Motherboard ASRock B450M-HDV R4.0 Micro ATX AM4 Motherboard $64.98 @ Amazon
Memory G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3200 Memory $69.99 @ Newegg
  Prices include shipping, taxes, rebates, and discounts
  Total $254.92
  Generated by PCPartPicker 2020-04-12 04:05 EDT-0400
you should find ryzen 5 1600 af (12nm) at amazon for 85 dollars
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
Type Item Price
  Total $254.92
I can go to at least 300-400$ so what should I upgrade there? And thank you for the help :)))
Type Item Price
CPU AMD Ryzen 5 3600 3.6 GHz 6-Core Processor $174.99 @ Amazon
Motherboard MSI B450 TOMAHAWK MAX ATX AM4 Motherboard $114.99 @ B&H
Memory G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory $84.99 @ Amazon
  Total $374.97
  Generated by PCPartPicker 2020-04-12 04:14 EDT-0400
for under 400dollars this will be nice.
decent motherboard and ram. good cpu
1 minute ago, Deus100 said:
B450 Steel Legend or Gaming Pro Carbon the difference here in Serbia is 100 euroes betwen these too. Is the Gaming Pro Carbon that much beeter?
Okay, after getting a 3600 and DDR4 3200 MHz RAM, what boards can you afford?
2 minutes ago, Deus100 said:
and is the 3600x better than 3600? It is a small money difference.
its not that much better. but if you want it, it comesx with better stock cooler. for 400dollars budget you can get it.
Type Item Price
CPU AMD Ryzen 5 3600X 3.8 GHz 6-Core Processor $199.99 @ Amazon
  Total $399.97
  Generated by PCPartPicker 2020-04-12 04:17 EDT-0400
Type Item Price
  Total $374.97
A member said that gaming pro carbon is good also. I can aford it so tell me is it better than b450? I see that you all recomend the b450 one.
is it b450 gaming pro carbon, x470 gaming pro carbon, or x570 gaming pro carbon?
Ryzen 3600x is 180 euroes in Serbia, Ddr is similiar so 85 euroes. And tomahaws b450 is 102 euroes so I can upgrade some of this stuff.  b450 gaming pro carbon is 140 euroes, x470 gaming pro carbon is 170 and x570 gaming pro carbon is 230
7 minutes ago, Deus100 said:
Both of these are ok after getting 3600x and DDR4 i can go to about 250 euroes
the x570 gaming pro carbon is better for future upgrades (cpu, ssd, gpu)
x570 boards support pcie 4 (for faster gen 4 m.2 ssd's and future gpu's)
x570 boards also run little cooler than b450.
x570 boards usually have better audio and internet too.
+ x570 boards look cool
But do you think it is worth that extra 100 euroes? In your experience.
for the long run it will save you more than 100 dollars.
