My old win7 laptop is having connectivity issues.
It's always either having limited access, stuck on identifying the network or it's just not able to connect at all. I have tried everything from reinstall the drivers to resetting the network settings. No luck. I might have to replace the network card. There are a few times in the day that I am able to connect but it's extremely slow. I troubleshooted the gateway as well. I even tried wired internet. It just doesn't work. Please help. I'm working with a Lenovo thinkpad.
https://linustechtips.com/topic/1176677-network-issues/
My next test would be to connect to a new network. A friends network, a new coffee shop whatever. If it acts the same it might be hardware failure. If it only happens on your network, then it might be a windows registry key or some other OS level thing.
https://linustechtips.com/topic/1176677-network-issues/#findComment-13473668
