Hi guys
So I have had this r9 390 nitro since 2016. In the summer of 2018, after I moved houses, my pc would boot up but then I would get no display.
The card works fine without any drivers but as soon as I install a drive, the display blacks out although the pc itself is working. I have a 550 watt power supply and my new CPU ( r5 2600) doesn't have on board graphics. Please help, I don't wanna spend money on a new card if this one can be restored
https://linustechtips.com/topic/1176120-r9-390-help/
Crashing when hitting higher clocks instead of just artifacting, that means the GPU itself has problems, unlikely the GDDR5s.... Baking it is the only way I can think of that might help, it's too old to be worth a treatment on a soldering station (i.e. to resolder the package onto the card)
Desktop benching:
https://linustechtips.com/topic/1176120-r9-390-help/#findComment-13467398
